Car cranks but won't start -- PLS HELP!!!
My car has '00 GSR swap into '99 EK. Been running the '00 Si ecu for a month, car runs fine.
Got the GSR ecu with immobilizer removed/replaced with dummy chip, but having a problem. So here's what happened.
1) Put the '00 GSR ecu in WITHOUT swapping A16 to A15: Car started up and then died after about 4 sec. => Tells me that GSR ecu is working fine but car not getting fuel since A16 pin swap not been done yet. Makes sense to me.
2) So I swapped A16 to A15: However, this time car will not start at all (keeps cranking only), with either GSR or Si ecu. Any idea why?
Any help is appreciated. Thanks.
