cant time b17 motor........please help
here is the deal.
my roommate has a 93 si hatch with a b17 swap. stock internals with basic bolt-ons and a skunk 2 ecu.
with the dist full advanced i can only get a total of 10 degrees.
we made sure the timing belt is on correctly and the motor will sit at tdc.
i swaped his ecu with my b16 del slow ecu....(p-30 i think) and the car will hardly run with a stock ecu.
we even tried using my b16 dist.
none of those things will work.
what do you guys think the bproblem is?
Re: (EG_Black_Hatch)
he just had the beld done by a shop here in vegas, and after that is when i noticed the problem.
he took it back and thay took it apart and said it was fine and couldnt give him an explanation.
i am going to pull it apart my self and check it out.
thats really the only thing that i can think of.
we also discovered a vacume leak. im going to pull the im, look that over and put it back with all new gaskets.
i think hit iac is also bad.
damn ghetto swaps......i told him not to buy the car.
thanks for the reply bro, chris
Re: cant time b17 motor........please help (the-anti-crack)
take the timing belt back off. make sure you align the cam gears so the lines line up, now move the crank pulley to the white mark, turn it about 1/4 to 1/2 an inch past the white mark so it falls in between the white and red mark. very close to the white mark TDC. then silde the timing belt on. I have had to do that a couple times but only when using adj. cams gears. let it get warm and check timing again. It should be fine, its always worked for me. good luck
david22ky
06-19-2007 02:36 AM
EK_vzla
09-16-2004 08:35 AM
