can someone tell me if a 96 delsol dohc a/c bracket and a 97 crv a/c bracket the same
i need to know asap, i know the crv bracket cost cheaper than the sol
Re: can someone tell me if a 96 delsol dohc a/c bracket and a 97 crv a/c bracket the same (roc)
check out http://www.hondaautomotiveparts.com
The 97 CRV AC bracket is functionally the same as the Del Sol P54 bracket. I own both brackets and am running the CRV one on my current setup.
The 97 CRV bracket will allow you to bolt up the 92-95 Civic AC compressor up to it (all 4 bolts). It works perfect.
Re: (roc)
I've been told the sol P54 and the CRV P7H are both ok to use when mounting a d series compressor to a b series block......now if I could only get my p54 in the mail...and hope I didn't get scammed....again......I'll be happy.....
just to confirm with everyone. the CRV is basically a DOHC EK Civic that sits a bit higher.
So yes i have the p7j bracket and it iwll work.
