Can i use my P.S. (EX) on a GSR engine?
Old 11-28-2003, 07:51 AM
Denis Si's Avatar
Default Can i use my P.S. (EX) on a GSR engine?
99 EX with PS can i use my stuff on a gsr that doesnt have powersteering anymore?
Old 11-28-2003, 08:01 AM
Moderator
chad's Avatar
Default Re: Can i use my P.S. (EX) on a GSR engine? (Denis Si)
only way to find out is bolt it up.....you might need to grind the brackets down some...
Old 11-28-2003, 08:06 AM
Denis Si's Avatar
Default Re: Can i use my P.S. (chad)
THANX MAN
Old 11-28-2003, 08:08 AM
Petah's Avatar
Default Re: Can i use my P.S. (Denis Si)
no....the pumps and mounting brakets are different. You will need 98 up teg part to reuse power steering.
Old 11-29-2003, 06:41 PM
BLK99VTECR's Avatar
Default Re: Can i use my P.S. (Petah)
actually it might work, i just got the same swap done wit the same year car as his and before i got it done my mechanic said that I wouldnt have P.S without some bracket but when the motor came he was able to hook it up because of something he told me that I forgot. But basically its possible depending on what the motor comes wit.
Old 11-29-2003, 07:03 PM
Denis Si's Avatar
Default Re: Can i use my P.S. (BLK99VTECR)
I see, so its just the pump that is different, nothing else right?
mhewitt
13
03-25-2011 12:34 PM
Nino_eg6
03-25-2009 01:26 PM
93civiconair
04-16-2005 09:02 PM
pennies_hatchie
12
09-23-2003 01:50 PM
BLK99VTECR
08-17-2003 05:41 AM
Quick Reply: Can i use my P.S. (EX) on a GSR engine?
