Mystery Line on a d16y8 head, need help! Pics inside!
here is the EX (D16y8) Head:
here is the DX (d16y7) Head:
Here are the lines going from the new y8 head to the y7 block
If you look at EX models (d16y8) there is a sensor the mystery y8 line goes to that is not present here on the y7 block, what the hell do i do? Where does the line off of the back of the y8 head go to on a y7 block? please help soon!
Re: Mystery Line on a d16y8 head, need help! Pics inside! (Civiclx)
EDIT its not on the head, its on the manifold! any advice?????
https://honda-tech.com/zerothread?id=691551
Can you put arrows to what you are talking about....since noone else seems to be helping maybe I can do some SEARCHing FOR you....What does the line go to on the Y8 and what SHOULD it correspond to on the Y7??
Re: Mystery Line on a d16y8 head, need help! Pics inside! (GTlvr82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 »</TD></TR><TR><TD CLASS="quote">Can you put arrows to what you are talking about....since noone else seems to be helping maybe I can do some SEARCHing FOR you....What does the line go to on the Y8 and what SHOULD it correspond to on the Y7??</TD></TR></TABLE>
if you look at the two auctions in the above link, 1 d16y8 manifold (pre 99) has no vertical pointing line but the 1999 up manifolds do have it ( right in the middle of the injector ports) does anyone know what this does on the 99 up and whether or not i can put it on my y7 1997 block
That's for the fuel injection air control system. (FIA) It sends extra air to the fuel injectors when the engine is cold to help keep the fuel droplet size small. (At least that is how it was explained to me.) It's another emmision control system.
Re: Mystery Line on a d16y8 head, need help! Pics inside! (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">That's for the fuel injection air control system. (FIA) It sends extra air to the fuel injectors when the engine is cold to help keep the fuel droplet size small. (At least that is how it was explained to me.) It's another emmision control system. </TD></TR></TABLE>
I fawking KNEW it....emissions owns you.
Yep. That is an extra air injection line. They added it for 99-00. That y7 mani is a 96-98. Just jbweld the extra little holes above the runners in the intake manifold shut (that's what I did a year ago and it works fine). If you don't you are going to have one massive air leak. Also make sure you get the intake manifold gasket for the 96-98 intake manifold.
how the heck do i bypass this? jb weld on the hole outside of the manifold?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">
how the heck do i bypass this? jb weld on the hole outside of the manifold?</TD></TR></TABLE>
Yiou don't need to j-b welt anything. Just plug the nipple the hose would go on.
Yiou don't need to j-b welt anything. Just plug the nipple the hose would go on. </TD></TR></TABLE>
Nope. I've done this first hand and it still leaks. Those air injecton ports don't have a corresponding hole on the 96-98 head and are connected to the runners of the intake manifold so I PROMISE it will leak if you don't weld those shut.
That is what I told him...why in the hell would you JB weld it.....
EDIT: ...is there something less permenent than welding it??
Re: Mystery Line on a d16y8 head, need help! Pics inside! (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Nope. I've done this first hand and it still leaks. Those air injecton ports don't have a corresponding hole on the 96-98 head and are connected to the runners of the intake manifold so I PROMISE it will leak if you don't weld those shut. </TD></TR></TABLE>
I've done it also, no leaks at all.
I got the answer thanks Riceymcricerton!
you plug it if the mani and head are both 99 up
you jb weld the holes shut if the mani is 99 up and the head is 96-98
That is what I told him...why in the hell would you JB weld it..... </TD></TR></TABLE>
Beacuse as I have said, that nipple is connected to ports in the intake manifold. Sorry, I just finished helping this guy over AIM and I thought he was putting a 99-00 intake manifold onto a 96-98 head. He is putting a 99-00 mani onto a 99-00 head onto a 96-98 block. Whoops, sorry for the confusion fellas. s on me!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 »</TD></TR><TR><TD CLASS="quote">Your welcome also you thankless bastard.... </TD></TR></TABLE>
Hey hey hey, now who helped him out through PMs and AIM???
haha thanks bro, i just got oil all over my keyboard and freaked out
u have an auto manifold... thats why that tube is there... if thats what ur talking about.. the piece where u capped it
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">BUMP</TD></TR></TABLE>
if you put an arrow to what you are talking about it would help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe »</TD></TR><TR><TD CLASS="quote">u have an auto manifold... thats why that tube is there... if thats what ur talking about.. the piece where u capped it
no, like was stated earlier, its for 99-00 air injection. There was a post a while back about plugging the holes. Keep in mind there are 4 holes on the manifold to head mating surface that are using that same injection system. I was told they needed plugging. Especially because if you look carefully the holes are wide open next to the injectors. THere was a post a while back about expanding rivits in the holes and using honda-bond to get a good seal. I just held out till I could find a 96-98 manifold.
BTW, I like your valve cover Civiclx, what paint did you use?
