Can I use a d16y8 head with a d16y7 ecu?
Can i use a d16y8 head without hooking up the vtec? i have to oreder the ecu si i wanna run the y8 head with y7 throttlebody and intake manifold just for now ,can i do that?
Fish Twig
Re: Can I use a d16y8 head with a d16y7 ecu?
vtec won't kick in so you won't have a problem, now if you tried to use a vtec controller to enable the vtec than that is where your car starts to run like ****.
Technical Hero
Yes because the idle air control valves are different. You'll also have to wire up VTEC and knock. Are you sure that's a y8 head because it's not a y8 manifold, more like a z6.
Technical Hero
-use your harness (or find a 96-98 ex harness for plug and play)
-add vtec, knock, and IACV 3-2 wire conversion
-if you use the ex harness you'll have to manually wire in the 2nd 02
-put your cars intake air temp sensor into your intake arm or convert to the round style on your z6 manifold
Y8 block/Y7 head/auto transmission - any issues with replacing Y7 head with Y8 head?
i have a y8 block with a y7 head
i just bought a y8 head so soon ill have a full y8
The car is an automatic (yes i know i need to go stick and i will as soon as i get the money)
any issues? thank you
Last edited by Former User; 03-02-2014 at 05:49 AM. Reason: Refocus thread on tech
Stancetard Hate Monger
Re: How to get the most out of an automatic vtec?
the problem you'll run into is that you can't run the y8 vtec ecu with your setup. the tcu is integrated in the ecu, and the y7/y8 transmissions are not the same. unless you convert to 5 speed or swap transmissions, no vtec for you.
why not?ive done all my homework on the swap, ive ordered the p2p obd2a ecu already and got all the connections i need and wires to extend the wires,the other post i made noone said i couldnt
I never narc'd on nobody!
The TCU is integrated into the ECU. The TCU controls the transmission. It expects the gear ratios for the transmission that came originally equipped with that ECU. An EX ECU cannot properly control a DX/LX transmission, and will throw a CEL because of it. A DX/LX ECU cannot properly control an EX transmission, and will throw a CEL because of it. For autotragic Civics, you HAVE to match the ECU to the transmission.
is there a way to check the trassmisson and see what model it is?the previous owner rebuilt the whole engine and had a full y8 but never put the head cause it was for the wife, anyway is there any marks on the trassmisson thatll tell me what kinda it is?
Z6 auto and manual use the same manifold. Y8 has two manifolds, one for auto and one for manual. If it was me, I'd get a Y8 auto manifold. I actually have a 99 Y8 auto manifold on my 99 Y7 civic and have had no issues since I put it on 1.5 yrs ago, even passed CA emissions testing with it
If you clean it off, there should be a casing code on it somewhere. If memory serves, it'll either be an A000 or B000, or something similar. Assuming your CEL isn't on right now, and you're running a DX/LX ECU, you have a DX/LX transmission.
