can i put a y8 head on a ZC block?
i just aquired a fully built ZC block. I have an extra y8 head and i was wondering if this sorta mix/match setup will work. i have a 96 civic coupe converted to obd1..if that helps...
Re: can i put a y8 head on a ZC block? (93CivicSI)
searched...to bad the search option doesnt allow me to use the word zc because it only has two letters...so yea....i couldnt find anything...anyone got a link for me, or sum info?
Re: can i put a y8 head on a ZC block? (Knightmare69)
im not sure wut kind of differance it will make, but i thought id try it out since i have the fully built block in my possesion.
Re: can i put a y8 head on a ZC block? (dryhopsux)
supposedly, the z6 head flows a little better and the y8 manifold flows better. Unless you messed up your head and need a replacement, dont worry about changin them
i have heard that if i put my y8 head on the ZC block it will mess up my timing and my car wont run right at all. ???????????????????????????
yes it will fit, will it make a hp diff hardly any, if on an eg you will need to change the intake mani since the head is an obd2 and an eg is an obd1
Moderator
Re: can i put a y8 head on a ZC block? (jspresso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspresso »</TD></TR><TR><TD CLASS="quote"> if on an eg you will need to change the intake mani since the head is an obd2 and an eg is an obd1</TD></TR></TABLE>
wrong wrong and more wrong!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
