Can I put a 2k Si gauge cluster into a 2k DX automatic h/b?
Re: (AutoEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoEK »</TD></TR><TR><TD CLASS="quote">plug and play </TD></TR></TABLE>
Re: (1bad-eg)
plug n play
unscrew the 2 screws on the top inside of your cluster bezel. then pull gently from the bottom of the bezel. the bottom is held on by clips that will slide out. then unscrew the 4 screws to release your cluster. pull the cluster out and unplug the 3 main plugs in the back. hook up the si cluster using those same plugs and reinstall. enjoy
