Can I get some help with 2 codes? 99 DX
Hello!!!!
I have a 1999 D16Y7 5 speed and its currently giving me (2) codes.
One code came on after I installed the header. I think that getting the secondary o2 sensor spacer should solve it but im not too sure.
Anyways, here are the codes:
1) P0132 CKT HIGH VOLTAGE
2) P0505 IDLE CONTROL SYSTEM MALFUNCTION
I was looking on Identifix.com and many people said something about a Vacuum leak for P0505. How would I check for that?
I have a spare IACV off of a 00' HX.
Re: Can I get some help with 2 codes? 99 DX
If you clear the codes, do they both repeat after driving the car?
Did you disconnect a vacuum hose and forget to reconnect it?
P0132 indicates a problem with the primary O2 sensor. Did you forget to reconnect it or not connect it tightly? Did you damage the O2 sensor wires?
As for the P0132, I put the primary o2 sensor on the runner of the header. Now its only measuring 1/4th the air because it was at the end of the header before. I extended the wires of the secondary o2 sensor though.
jss43
03-07-2014 03:26 PM
HommeDeBois
15
07-16-2011 02:56 PM
