Can having a D-series Throttle body on my B18B affect my Idle?
Old 04-14-2007, 05:07 PM
CSHornet60's Avatar
Default Can having a D-series Throttle body on my B18B affect my Idle?
I currently have my D16y8 Throttle body on my b18b because the one it came with had a broken TPS sensor. My car is idling a little funny. Can this be my problem? I have already sprayed around for vacuum leaks. Thanks!
Old 04-14-2007, 05:16 PM
Lord Milferdeen's Avatar
Default Re: Can having a D-series Throttle body on my B18B affect my Idle? (CSHornet60)
im not positive but isnt the D series throttle body smaller than the B18B's ?
Old 04-14-2007, 05:28 PM
pythoner's Avatar
yes its smaller, its like snorkeling with a straw insead of a snorkel!
Old 04-14-2007, 06:08 PM
CSHornet60's Avatar
Default Re: (pythoner)
When i rev my motor is fine but when it comes back down... It almost stalls out.. So most likely it is the throttle body?
pythoner's Avatar
when I had the wrong TB, it was lacking power...that was it
Old 04-14-2007, 06:21 PM
CSHornet60's Avatar
What can cause my car to almost want to stall after the RPMs come down after i rev it? Thanks!
Old 04-14-2007, 06:28 PM
92hatch_cx-t's Avatar
Default Re: (CSHornet60)
it might be a vaccum leak but im not sure...mine does that too
or a sensor
Old 04-14-2007, 06:36 PM
pdiggitydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner &raquo;</TD></TR><TR><TD CLASS="quote">yes its smaller, its like snorkeling with a straw insead of a snorkel!</TD></TR></TABLE>
yeah because 2mm is SOOO much smaller
look for a vacuum leak
-Todd-'s Avatar
Default Re: (92hatch_cx-t)
Well, did you just now put the y8 tb on it and started having this problem or have you had the y8 tb on it for awhile and you started having problems? If you just put it on and had problems then im willing the bet its the y8 tb causing it. Are'nt most honda tps sensors the same? Could'nt you swap them?
Old 04-14-2007, 06:39 PM
pythoner's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">
look for a vacuum leak</TD></TR></TABLE>
I had a CX TB on a D16z6...and I only said it was smaller, not how much smaller!
Old 04-14-2007, 06:46 PM
straw vs snorkle makes it seem like you meant as if he were suffocating it
Old 04-14-2007, 08:05 PM
CSHornet60's Avatar
I did the swap a week ago. Its a B18B into a 96 Civic EX. I was going to switch over the TPS but i dont know how to calibrate it.
peteyparado
05-13-2013 06:35 PM
SIDeghatch
11-08-2006 04:57 AM
singlestic
Northwest (Sales)
10-05-2006 10:12 AM
unknown0001
05-30-2006 02:29 PM
MrEg
09-24-2003 02:52 PM
Quick Reply: Can having a D-series Throttle body on my B18B affect my Idle?
