Camber problem stock suspension
Old 02-16-2006, 09:55 AM
93preludeh22's Avatar
Default Camber problem stock suspension
So, I had an alignment done today because my car was shaking like a pita while accelerating and at high speeds. (high speed problem not fixed by the way)
I noticed that my front left camber was -1.4 degrees and the front right is +0.8 degrees.
What would cause my camber to be off so much in the negative on the front left?
The car kind of sags a little... could it be old springs?
Let me know,
thanks
Anthony
PS. 95 Civic Hatch w/ H22 swap. Stock suspension/tires/rims... (don't ask) stock exhaust too.....
Old 02-16-2006, 12:23 PM
sohctodohc's Avatar
Default Re: Camber problem stock suspension (93preludeh22)
i could be wrong but i have heard you need stiffer springs when you throw a h22 into a hb. so that could cause the front to be sagging. now why they are different on each side i dunno. maybe one spring is starting to sag and thats causing the otherside to sit up more? hell i dunno
Old 02-16-2006, 12:37 PM
Yah, you definately need better springs to run h22 I'm broke though
Is it possible that the spring is original... is there a way to check if it has sagged? Can I jack up the car and measure? or measure with it compressed by the car??/
thanks
Old 02-16-2006, 01:01 PM
HXvtec's Avatar
Default Re: (93preludeh22)
hmmm. maybe they screwed up on your alignment.
Old 02-16-2006, 01:17 PM
The car appears to be visibly sagging too
Old 02-16-2006, 04:57 PM
why is my car sagging!!!?
Old 02-16-2006, 05:54 PM
As long as I dont have to take out any more Metal Gears
rukawa1one's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">why is my car sagging!!!? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohctodohc &raquo;</TD></TR><TR><TD CLASS="quote">i could be wrong but i have heard you need stiffer springs when you throw a h22 into a hb. so that could cause the front to be sagging. now why they are different on each side i dunno. maybe one spring is starting to sag and thats causing the otherside to sit up more? hell i dunno</TD></TR></TABLE>
Old 02-16-2006, 10:19 PM
sohctodohc's Avatar
Default Re: Camber problem stock suspension (rukawa1one)
old springs+h2. thats your answer. just get a set of eibachs so they wont sag they have warranty against it and it wont lower to much to cause binding issues+alignment. and you will be set.
Old 02-16-2006, 11:08 PM
SIRIUS EJ8's Avatar
yep heavy *** engine in tiny *** car....hook up the springs homie...Listen to sohctodohc comin from 96tosi
Old 02-17-2006, 04:39 AM
Thanks guys! Hopefully it is only the weight+old springs. I'll get a set of eibach springs
invader_zim
04-04-2012 12:08 AM
.I.Need.Money.
Suspension & Brakes
02-23-2007 01:04 PM
melissas_man2004
05-25-2005 02:44 PM
eclypzex
10-06-2004 01:28 PM
FD3S
08-02-2002 10:21 AM
Quick Reply: Camber problem stock suspension
