camber kit Q: Do they really help?
Old 05-05-2003, 02:10 AM
SRd240sx's Avatar
Default camber kit Q: Do they really help?
My friend says that some people say they don't really help much, if anything at all. He says they're a waste of money. My camber on my car is horrible with only a 1.5 inch drop... I've gotten an alignment and it still is pretty bad so I bought a Skunk2 camber kit for my 98 Civic. My friend says all I need is an alignment to correct the toe. Now I know toe has alot to do with wearing out the insides of your tires, but what about camber? Am I just wasting my money on the camber kit if all I need to do is adjust toe to fix my problem?
Old 05-05-2003, 02:40 AM
civicmandx94's Avatar
IMO I would use the camber kit, I mean you allready have bought it. It will help with traction and it will keep your tires from wearing unevenly.
Old 05-05-2003, 03:57 AM
VTEC-DA's Avatar
Default Re: (civicmandx94)
Your friends an idiot. Look at a civic that been lowered 2" without a camber kit and then look at one thats been lowered 2" that has a camber kit. You tell me if a camber kit works or not.
Old 05-05-2003, 05:38 AM
Jet Phi's Avatar
Default Re: (VTEC-DA)
man install that shiznit on yoor car
yoor friend deserves a
Old 05-05-2003, 05:44 AM
Paranoid Android's Avatar
Default Re: (b 1 6 a 2)
use the camber kit...you cant go wrong with it..if you have any kind of drop at all its safe to use. most ppl dont use it until they hit a bout a 2.0 inch drop, but diff cars, diff results...
the camber kit will even you out,...you wont tear up your tires..., better ride quality..etc
Old 05-05-2003, 06:15 AM
piscorpio's Avatar
Default Re: camber kit Q: Do they really help? (98civichb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civichb &raquo;</TD></TR><TR><TD CLASS="quote"> Am I just wasting my money on the camber kit if all I need to do is adjust toe to fix my problem? </TD></TR></TABLE>
Yes, if toe is your only problem, there is no need for a camber kit. However, you said your camber is way off, even after an alignment, so you will need a camber kit if you want to adjust the camber.
How far off is your camber? It seems odd to me, because my 00 Civic was lowered about 1.5 maybe 2 inches and never really displayed any bad camber (I think it was 1.6 degrees or so).
Old 05-05-2003, 06:24 AM
Fuster_Cluck's Avatar
Default Re: camber kit Q: Do they really help? (piscorpio)
Having the toe aligned to "0" will help! But, still rolling with tires like:
will still cause uneven wear.
Your friend gets a from me
For the rear just use longer bolts and washers
Old 05-05-2003, 06:27 AM
JaeOne3345's Avatar
Default Re: camber kit Q: Do they really help? (Hybrid93Hatch)
toe usually does more damage then camber, but most people dont know that. if i had to pick one and i was on a budget, id go for tow first. if u can, go both. but remember, u can tune toe and camber to greatly help the handling of your car at the expense of tire wear. im willing to take that expense.
Old 05-05-2003, 06:32 AM
GDM Z28's Avatar
Default Re: camber kit Q: Do they really help? (JaeOne3345)
i have a 95 civic hatch with a 2" drop (H&R springs) my camber was BAD im talking like almost -3 degrees if not worse! I bought a eibach camber kit that adjusts up to 1.5degree and it helped ALOT! i would wear out tires in about 3 weeks and now my kumhos have been on the road for almost 2 months and i have not seen any wear! Use the camber kit but before you do throw it at your friend!
Old 05-05-2003, 06:37 AM
makaveli284's Avatar
Default Re: camber kit Q: Do they really help? (civicflnum1)
How much does a camber kit run, for a 2000Civic ? ?
Old 05-05-2003, 09:10 AM
BeeSeriesEK4's Avatar
Yep camber kit definately helps. U can even feel it working. It feels different when u have more of a contact patch with the ground. It also handles differently in the turns. With camber its much better ofcourse. But now atleast u don't kill your tires. And a camber kit does seem to throw off your alignment. It did with my car. I got the Skunk2 camber kit, it made my car toe out. So you just have to adjust the toe back in. I don't know if that's the case for everyone. But a couple of my friends experienced the messed up alignment after as well, but it was fixable.
Old 05-05-2003, 09:45 AM
tonyxcom's Avatar
Default Re: camber kit Q: Do they really help? (BeeSeriesEK4)
I ran -1.75 F and -1.5 R camber on my car for 13-15k on one set of tires and I had no camber wear. What is the secret. ZERO TOE.
im not going to get into this again, SEARCH!
91EF919
06-30-2009 04:11 PM
sublimeh215
Suspension & Brakes
02-10-2009 07:34 PM
crx1009
04-05-2006 09:57 AM
itsJDMyo
13
01-07-2005 10:40 AM
Quick Reply: camber kit Q: Do they really help?
