cali smog with CRANK angle sensor...need help ASAP!!
i was wondering if there is any way to pass cali smog to get a bar sticker with a jdm ecu. if not then is it going to throw a cel when i put the usdm ecu in since there is no crank angle sensor hooked up... will i need to hook it up . thanks alot
Re: cali smog with CRANK angle sensor...need help ASAP!! (zzZZzzleeperCX)
when i switch ecu to the usdm, will it throw a CEL from not having the crank angle sensor...it is roughly 400$ so i want to know before i do it. thanks
Re: cali smog with CRANK angle sensor...need help ASAP!! (Pho Real)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real »</TD></TR><TR><TD CLASS="quote">Yeah, the ECU is going to still throw that code. You need to fix the Crank Angle Sensor...</TD></TR></TABLE>
yeah Pho Real
lol that has 2 meanings to it
yeah Pho Real
NathanMorris
02-10-2008 01:45 AM
Redbone
02-18-2007 11:26 PM
