Throwing codes, but are they correct?
Old Aug 19, 2011 | 09:58 AM
dkrangers's Avatar
Default Throwing codes, but are they correct?
My car has been stumbling and having hard start issues all summer. Finally this week I get my hands on a P2T ecu, ran that and pulled 1 code.
Vehicle - 2000 Civic Si
Engine - B18C JDM 96-97 Type R
ECU's - P2T 99-00 SI, JDM 96-97 ITR
The code I got was for the crank position sensor, but the JDM ECU I usually run never threw this code. Is the USDM ECU looking for a crank position sensor down by the crank shaft and because the JDM motor doesn't have it, it is throwing the code?
I'm hoping the USDM B16a2 is similar to the JDM B18C and that this is my problem because I've been chasing it all summer and haven't gotten to autox or anything this year.
Old Aug 22, 2011 | 01:38 PM
hybridmiklo's Avatar
Default Re: Throwing codes, but are they correct?
obd ecus look for the crank position sensor thats located by the oil pump. The jdm motor is not equipped with that separate crank sensor
Old Aug 22, 2011 | 05:27 PM
boostedteg909's Avatar
there r a few diy threads on how to bypass the crank fluctuation sensor. it needs to b done if ur si ecu is lookin for the sensor but the engine doesnt hav it. happened wit my buddys em1 as well. the jdm ecu doesnt look for it at all which is y ur havin this problem only wit the usdm ecu
Old Aug 22, 2011 | 05:51 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
http://ff-squad.com/technet/ckftrick.htm
Old Aug 23, 2011 | 07:09 AM
dkrangers's Avatar
got it figured out, thanks.
Unphzd
18
Apr 5, 2012 11:55 AM
Redbone
Feb 18, 2007 11:26 PM
wambamcivic
Dec 10, 2004 10:43 PM
tyflip2
Dec 5, 2003 08:32 AM
