A/C button broke off on my 98 civic ex. A/C is stuck on now
So I just purchased a 98 ex sedan from someone 3 hours away. I asked tons of questions, one of coarse being does the a/c work. He replies yes it does. I go and pick up the car and notice right away that the button looks to be stuck in or ON. I go back and ask, he said sorry idk what is wrong and I didn't think to tell you as you only asked if the a/c worked. So I get back home and find the the button is actually broke off and just set in the hole. So I have no idea how to shut the A/C off. Just wondering if there is something else I can stick back in the hole to turn it off and on or if I need a new climate control for the car.
Re: A/C button broke off on my 98 civic ex. A/C is stuck on now
You can buy the button for $7.50 at Honda.
Honda Automotive Parts
Is something also broken inside the climate control where the button inserts? I can't tell from the picture.
That's what I don't know. I've never messed with a climate control before not sure if I get a new button if it will completely fix my issue. What does the button push down on inside? I mean honestly, if I can just use a small flat head screw driver to turn it off and on by depressing something inside of there I will as this is just a beater dd, but I do want to be able to turn it off as well
Definitely figure out if you can turn the A/C on and off with a screwdriver or pick. Also check whether the part that broke off the button is still stuck inside the climate control.
If all fails, pick up a climate control from a junkyard.
That's what I was thinking all the way around. I just wanted some reassurance as to that being my best way to hit it. Thanks for your help. I'll prob just give in and get a new climate control.
Remove the recirculation mode button and try it on the a/c. They are the same. The one you have looks to have a broken part.
98savage
06-16-2007 08:39 AM
