A/C always on with chipped ECU
Old 05-22-2014, 07:01 PM
psychobear's Avatar
Default A/C always on with chipped ECU
Car is a 92 Civic Hatchback DX with a d15b vtec with a p28 ecu chipped with p08 fuel maps.
The ecu makes the AC compressor always be on, this was verify cause we swap out and put a stock p28 ecu and it will on turn on when AC was on. We also tried it with a p06 and p28 ecu chipped with hondata. I will add and attachment with what my mechanic came up with.
My question is will I need to get a new ECU or make my current one work?
Old 05-22-2014, 08:04 PM
Former User's Avatar
Default Re: A/C always on with chipped ECU
Yes, the ECU is bad.
Old 05-22-2014, 08:32 PM
psychobear's Avatar
Is it safe to use until I get a different ECU or do I just stop using it? Everything else seems to be running fine.
Old 05-22-2014, 08:56 PM
If you don't mind the A/C running constantly, then it's fine. Or you could set up a toggle switch.
Old 05-22-2014, 09:05 PM
psychobear's Avatar
Cool sounds good, thanks Ron.
Old 05-22-2014, 09:16 PM
On second thought, you should unplug the compressor and disable it until you get the new ECU. The reason is that the compressor in it's current state can't be turned off by the thermostat. This will cause the evaporator to become encased in a block of ice.
Old 05-22-2014, 10:21 PM
psychobear's Avatar
Yeah that's what I ended up doing when the notice it was running with the AC off.
2camsaam
13
10-02-2015 12:44 PM
hondaEg_808
03-25-2008 11:10 PM
BoostedH
02-19-2008 01:41 PM
TypeR0wnz
02-15-2003 04:47 AM
Quick Reply: A/C always on with chipped ECU
