93 del sol ac system
I have a 93 del sol and the last owner took out the ac system but the ac bracket is still there I wanna kno what other honda ac system would fit?
Re: 93 del sol ac system
yeah correct 92-93 civic work great if you have 92-93 delsol.
i would recommend up grading to full r134A system out of a 94-95 civic.
since r12 is hard to get now. just did mine in my delsol i have a 93 but came up on a full system out of a 95 civic using the marketplace a guy was parting out his sedan.
a/c is blowing cold !!!! good luck
96-97 delsol use a bigger compressor a/c system from 96-00 civic will work
everything will work srry on the late response. but everything depending on which systems you use! when i say this i mean 92-93 a/c systems can not interchange parts with 94-95 civic. when you dealing with a delsol look at it like its a regular civic they share basicly the same chassis. i no you have a 93 but thats r12 system and is a little harder to deal with if it hasnt been converted over to r134a yet. if your on the market for a/c i would defently look for 94-95 system because its a r134a system oready and makes things way easier.
everything fits off civic directly into your car with absolute no issues.
if you go with 94-95 civic a/c set up everything works the evaporator will bolt up into your underdash compartment. and the hoses will curve out to there rightful spots. condensor will clear the header fine, and air drier will fit in its corner as it should, only thing you will need is the evaporator temp sensor off a 92-93 civic because it will be a 2plug wire like your under dash harness is. and the 94-95 civics use a 3 plug wire. besides that minor thing everything fits just as it should
