Brian Crower stage 2 or stage 3????
i decided not to go with skunk2 camshafts! i was wanting to know which stage brian crower camshafts i should get for my set up! here is my buiild
ls/vtec:
b18a1 bottom and b16a head
valvetrain: brian crower dual valve springs and steel retainers, blox flat face high compression valves!
bottom end: p30 pistons, stock sleeve and stock bore (11.7:1 compression), stock crank, stock mains and bearings..
miscellaneous: skunk2 intake mani., skunk2 fuel rail, short ram intake, high flow exhaust (full exhaust)..
thank you!
ls/vtec:
thank you!
Re: Brian Crower stage 2 or stage 3????
exactly what i thought to! i just wanted some opinions first! stage three is for like highly build engines, stage two is for like moderate.. i will go with stage two most likely! thank!!!
JinteDgraM
03-20-2005 09:06 PM
Fab-Works
03-30-2004 10:10 AM
