Brakes issue!! HELP
Brakes issue!! HELP
okay 94 honda del sol s. the front brakes are holding pressure as if i was riding the brakes! i thought maybe the calipers might be sticking or something so i changed them and still the same. i changed the lines i changed the proportioning valve, master cylinder and the booster and it still does it. like the car will drive fine but as you drive the pedal gets stiffer and harder untill the brakes actually are applied all the time. if i let it sit over night it will go back to normal again.
im frustated as hell ive changed everything i can think of.. any suggestions???
yes i do mean I did it. and yes i have thought about the possibility that maybe i might have done something wrong but i went back and checked everything over twice. another thing i was suggested to change was the master cylinder cap. which i just picked up today i will find out if it helps tomorow.. after i rechecked everything i am confident that i did everything correctly. also i triple checked to make sure the brake lines werent twisted even a tiny bit.
jasonweaver88
06-29-2007 10:31 AM
