brake upgrade...help
Guest
Posts: n/a
im planning on upgrading my brakes.
1st question, im currently running stock cx brakes and rotors. will it help any if i just change the rotors and pads?
2nd question, if the above wont help at all, ill probably do a gsr swap. what exactly will i need to upgrade from a non-abs eg cx to gsr? is it a direct bolt on? i only plan on doing the fronts to keep it cheap and stockish.
Re: brake upgrade...help (EG type GTR)
https://honda-tech.com/zerothread?id=820484
hope this helps ^^^^
as for the swap, yes everything bolts straight on.
Marktwo
17
07-25-2004 09:03 AM
Chugger
10-07-2001 07:36 AM
