brake lights not working
Old 07-15-2013, 07:58 AM
digitalvice's Avatar
Default brake lights not working
92 eg6.... checked bulbs they were fine, replaced them anyways. now im looking at the brake switch. it seems to engage but i've lost the clicking noise it makes which leads me here. before i buy a new switch i wanted to know if there were any other possibilities, either the fuse or something else. whats weird is i replaced the drivers side front wheel bearing yesterday which is when my lights cut out. tail lights, turn signals all work.
Old 07-15-2013, 08:07 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Default Re: brake lights not working
You check the fuses?
Old 07-15-2013, 08:49 AM
Former User's Avatar
Does the horn work?
Old 07-15-2013, 09:59 AM
the horn hasn't worked for months...i thought that was due to my dash harness being hacked to **** when i got it, also leading to no clock or stereo. and yes i did check my fuses there are 3 20's in the middle of the bottom row that are showing no power. the rest are fine. im looking through the service manual now to find out what they are
Old 07-15-2013, 10:06 AM
The horn/brake light fuse is located in the hoof fuse box -- 20A fuse #42.
Old 07-15-2013, 10:07 AM
ok i will check them now.
Old 07-15-2013, 11:37 AM
ok so i have ran a check on the fuse its fine... managed to get my radio and clock working again, but no brake lights or horn
Old 07-16-2013, 07:04 AM
bump...i have replaced my brake light switch with no luck. my brake lights are still out as well as my horn. also replaced fuse #42 used a volt meter everything looks good. any ideas?
Old 07-16-2013, 07:42 AM
Does #42 have voltage on both top test tabs?
Does voltage reach the brake light switch on the pedal?
Old 07-16-2013, 07:48 AM
yes. i checked the voltage on both tabs and the switch when i replaced it this morning. could it be a ground?
Old 07-16-2013, 07:49 AM
Originally Posted by digitalvice
i checked the voltage on...the switch when i replaced it this morning.
And the answer was...?
Does the car have cruise control?
Old 07-16-2013, 07:51 AM
it has voltage at both tabs and at the switch. i did read somewhere that the cruise control could play a factor. i took the car around the block about an hr or so ago and put the cruise on, it turns off when pedal is depressed
Old 07-16-2013, 08:01 AM
As you have cruise, the next question is did you probe for voltage on the power wire for the brake lights? Which specific pins in the switch connector have voltage?
Old 07-16-2013, 08:20 AM
the power wire has voltage. it read at 13.84 could that be the problem? also i tested a and b. on the connector. top 2
Old 07-16-2013, 08:23 AM
State voltage readings for specific wire colors.
Pin B in the connector is the power wire for the brake lights.
Old 07-16-2013, 09:23 AM
green/white 13.84;
grey 4.0 without cruise switch;
12.1 with cruise switch on;
light green 13.46;
light green/black dots 13.83
green & green/white (plugged into the same slot) 12.6
Old 07-16-2013, 09:25 AM
pin B is the green/white
Old 07-16-2013, 10:46 AM
Good. With brake pedal pressed down, now check whether voltage reaches the Grn/Wht wire terminal at each brake light bulb receptacle.
Also run power and ground wires from the battery posts to the horns to see whether they sound.
Old 07-16-2013, 10:54 AM
i will run the tests now.
Old 07-16-2013, 11:06 AM
the most i would get is from .8-3.0 but no lights. the horn doesn't work either. i think its actually broken.
Old 07-16-2013, 11:13 AM
The horn is broken. Replace it.
What did you use for ground in your voltage test in the receptacles? Compare the metal chassis versus the brake light ground wire. If both grounds yield low/no voltage, then the Grn/Wht wire running between the brake pedal switch and the rear receptacle is broken. You can either locate the break and fix it, or run a new wire.
Old 07-16-2013, 11:15 AM
i used the G553 ground bolt.
Old 07-16-2013, 11:16 AM
Try using an adjacent clean metal area of the chassis, just in case the G553 bolt is corroded.
Old 07-16-2013, 12:21 PM
same results. also pulled the interior quarter panel out and traced the wire to the switch and there is no frays or shorts. there is just no power through that wire. but there is power at the switch terminal. confused...
Old 07-16-2013, 12:25 PM
Does voltage reach the Grn/Wht wire at the point where the connectors link the dash and floor harnesses? The general strategy would be to test for voltage on the wire at points close to the switch and then to move farther away until no/low voltage is detected. That should help pinpoint the break.
Quick Reply: brake lights not working
