BRAKE LIGHT KEEPS COMING ON
ok well my hand brake light comes on all the time. when i takje off up untill fourth gear it stays on then after im in fourth it goes off.
but sometimes if im in third and i let off the gas it turns off the it turns back on when i give it throttle i can seem to figure out why this is happening is it because my brakes are low in the rear or what i am stumped
Re: BRAKE LIGHT KEEPS COMING ON (hatch96y7)
Have you checked your brake fluid level? Maybe its low. I had the same problem once. Filled my brake fluid reservoir and the light never came on again while driving. Also check the switch under your e-brake. It may be loose. Other then that I don't know what else it could be.
Re: BRAKE LIGHT KEEPS COMING ON (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">LOW BRAKE FLUID!!!!!</TD></TR></TABLE>
Ditto, Did a brake job, bled the system, no nlight for like 2 weeks, then it came on so I thought it couldn't have been the fluid, but it was.
