Brake dorks, I need your help! Anybody ever done a 5 lug on EG and retained the stock abs stuff???
Okay I know that the abs ecu has crazy mathematics in it set up w/ logarithms for the stock braking system. I know that by changing a proportioning valve or calipers that this will/can drastically mess up the computer. So I am assuming that by using ITR 5 lug brakes w/ the ITR master and propo. valve that should mess up the computer. I also realize that the ITRs stock ABS unit is supposed to be way more advanced than the stock EG stuff. Thus I am under the impression that I cannot use the ITR's ABS ECU. So is there anyway (other than swapping the ENTIRE ITR ABS unit) that I can make this work? And even if the ECU would work, it is designed for a car that is much heavier, so it still shouldn't be quite right, right? Any help is greatly appreciated!
Re: (BLAME_canada)
maybe youd get more replies if you didnt call them dorks! all people have feelings!
but im still bumping your thread cause thats wat ht is for (info)
I'm a Jackass
i have a 94 SI with a 5 lug conversion also and i retained my ABS all the **** just plugs right in make sure ur abs fuse box has all its necessary fuses or else u'll get an abs idiot light
Re: (Benzo2NED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benzo2NED »</TD></TR><TR><TD CLASS="quote">only things i swapped were the trailing arms, hubs, and spindles and calipers</TD></TR></TABLE>
So you used the ABS sensors that came on the trailing arms and front spindles?
I think mine are cut so can i just rewire the sensors to the OEM ABS wires.
gino11
04-28-2007 12:16 AM
NIKE SB'd
06-18-2004 11:11 AM
