Help diagnose clutch chatter...
I've got some sort of chattering sound coming from my clutch. It sounds almost like valves chattering, but it goes away if I press my clutch in just a little bit. It sounds like something is maybe just brushing against the flywheel??? I'm clueless. Any help appriciated
Re: Help diagnose clutch chatter... (G3NR8)
Sounds EXACTLY like the proplem i had, When i rebuilt my tranny i dident tighten up the interlock quide bolt, so it was just kissing the pressure plate. that my .02
Re: Help diagnose clutch chatter... (nocternaldragon)
I haven't put a new clutch in since I had it, but the monkey that owned it before me did....he prolly fucked something up.
Re: Help diagnose clutch chatter... (vjace)
same thing happened to me, but after a few passes at the strip it mysteriously stopped. I don't recommend doing that, but I have had no problems out of mine, and that was about 3 months ago. It's probably just your throw out bearing.
Re: Help diagnose clutch chatter... (slowest_ls_swap_ever)
Mine did the same thing when I stepped on the pedal before my clutch went out and it was the disc. The threads in the middle of it were slowly being wore by the shaft and one day it just went out I thought I blew my tranny but it was just the disc. I talked to the ACT guy at the battle and he told me they designed the clutches to do that. A guy with a 96 ex had the same problem but it was that the clutch was installed wrong and the throwout bearing.
Re: Help diagnose clutch chatter... (sloboy_eg)
It sounds like your input shaft bearing. I had the same problem, but I had a new clutch installed when I got my new engine. I had a new throw-out bearing installed but the sound is still there. With the clutch depressed the input shaft stops spinning so the noise from the bearing goes away. Just my.02!
ls2poweredgoat
04-24-2009 02:24 PM
VTECAcuraGSR
03-02-2007 07:36 PM
kevpotts
03-03-2006 06:23 PM
colesd16
06-28-2004 08:22 PM
