Brake Conversion for 00 Civic Dx
I have a question regarding for 2000 Civic Hatchback on suspension.
If I wanted to go from stock drum 4x100 lug brakes to GSR 4x100 or Dc2 96-97 Disk brakes would it fit right with the current upgrades that I have for my current setup?
I have UCA's, LCA's, Buddy Club Coilovers, Rear Camber, and Subframe etc.. will they fit the brake conversion? Or will I have to get parts to fit the brake conversion?...
Many Thanks
Many Thanks
Re: Brake Conversion for 00 Civic Dx
The rear's will bolt right up, complete plug and play except for the ebrake cables which you can swap from a 99-00 civic SI.
I'm pretty sure the front disc brakes will not fit with the integra hub, you have to acquire 96-00 civic EX hub/knuckles and bolt on the integra caliper/mounting bracket for everything to work.
The 96-00 civic ex and 94-01 integra both use a 10.3" front rotor so there's no problem there, but the integra caliper is slightly larger than the EX one if you prefer more stopping power.
Thanks guys so much for useful information! This is a big relief knowing that..
Now would it be better if I get the whole disk brake conversion for front and rear or can I keep my front brakes, (upgrade them aftermarket wise) and just convert the rear from drum to disk?
Thanks again
Thanks again
98dxhatchbuild
09-23-2017 02:29 PM
Arthas
03-15-2011 01:18 PM
hondapimpin420
02-02-2009 11:47 AM
