Brake Booster question LEAKING!
Old 06-19-2004, 06:50 PM
MiX
MiX's Avatar
Default Brake Booster question LEAKING!
I have changed out the piping and know its not that. My brake booster feels like its leaking from the firewall. Like where the brake booster meets the firewall. I have pressure but it leaks, so when i brake hardm, i lose pressure at the end of braking. And when i turn off my car u can hear it "hisssssssssssssss". Any suggestions of what is wrong is great. thanks.
Old 06-20-2004, 12:12 AM
BatuKing's Avatar
Default Re: Brake Booster question LEAKING! (MiX)
You might have a leaking diaphragm.
get a vaccum pump and attach it to the booster directly (do not leave the check valve installed) and see if it holds vaccum if not then its leaking and bad.
Old 06-20-2004, 05:14 PM
MiX
MiX's Avatar
could you be more specific, what is a dighragm
Old 06-20-2004, 05:38 PM
FourthGenHatch's Avatar
Default Re: (MiX)
There is a rubber seal between the booster and MC that holds pressure in, that is probably going bad. Same thing happened to me before.
Old 06-20-2004, 07:06 PM
MiX
MiX's Avatar
Default Re: (FourthGenHatch)
so you think its that seal and not the one behind the actual brake booster.
Old 06-20-2004, 07:07 PM
dogfood's Avatar
Default Re: (MiX)
does it get harder to brake?
Old 06-20-2004, 10:38 PM
MiX
MiX's Avatar
Default Re: (dogfood)
well when i brake it seems alright when i first start to brake but when i brake hard it gets mushy then hard at the end. and it sounds like my brakes lock up, But then again i dont have abs so they would lock up. But it makes weird sound. Like i can be in park and brake and i heard werid noises. But i just want to make the hissing sound stop when i kill the motor.
Old 06-20-2004, 10:47 PM
BatuKing's Avatar
Default Re: (MiX)
Its inside the booster
Honda CR-V & Element
05-13-2017 05:41 PM
stevescivic
13
04-14-2014 02:23 PM
PatrickGSR94
03-26-2004 01:19 PM
Xumarius
10-10-2003 03:22 PM
Quick Reply: Brake Booster question LEAKING!
