control arm advice
control arm advice
my control arms went bad im looking at getting new ones am i better off going aftermarket or keep it oem? If i go aftermarket is there a significant difference in the handling?
Thanks 4 the help
-the noob
Thanks 4 the help
-the noob
Re: control arm advice (Teal5GenHatch)
There's no advantage of aftermarket control arms other than adding a sway bar hole in the rear, and being lighter. If you need a quick replacement while not having to spend too much money, used OEM is the way to go.
But then again, what control arms are you talking about? Front upper, I would consider a camber kit arm if your car is lowered.
Re: (Teal5GenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teal5GenHatch »</TD></TR><TR><TD CLASS="quote">ya its dumpd on tein dampers so go with camber kit arms. Im getting a skunk2 camber kit tomar should i pick up some arms while im there? What Co. should i use</TD></TR></TABLE>
Some good rear LCA would be Ksport, Omni, SRR, Function, theres a bunch
Re: (Teal5GenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teal5GenHatch »</TD></TR><TR><TD CLASS="quote">they wont give my car a lower stance will they i was looking at the omni's </TD></TR></TABLE>
Nope. They are basically bling OEM replacement with a sway bar hole.
Re: (Teal5GenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teal5GenHatch »</TD></TR><TR><TD CLASS="quote">lol thanks so they wont help it handle any better it all its a bling factor with a swaybar hole</TD></TR></TABLE>
Exactly.
Exactly.
