both doors?
both doors?
I have a 96 Ex coupe, on my drivers side door, the lock doesnt always work with the keyless entry. Also, on the drivers side door, the window gets stuck and falls off the track and won't roll back up, so i have to take off the door panel and put it in the track again. On my passenger side door the window rolls down fine, but rolls up very slowly. Its gotten stuck once, but it rolls back up in a matter of minutes. I was wondering if there was an easy way to fix this, or should I just buy new doors? Thanks for the input guys
Re: both doors? (knockout)
I wouldnt buy new doors.. that seems kinda spendy.. But I would just try and see what the problem could be.. It seems like it falls off the rail becuase its slips off somwhere so try and figure out where thats at and then the keyless entry it seems like the lock maybe hitting something like maybe you didnt put the pannel back on right or the door handle trim ****...
Re: both doors? (Ls_V_TurboSi)
i've put the panel on right, its actually fallen off 4 times now, kinda have it down now. The bracket that holds the window just wont hold it in, ive even adjusted it (as much as i could considering its IN the panel) I just might have to buy new ones thanks again.
go to honda and get some silicon spray. most likely your windows are sticking to the window tracks. Keep trying to roll them up and the regulators will burn up. Might also wanna pull off the door panels and grease up your tracks/rails. most likely your windows popped off the scissor tracks.
le0ftw
02-08-2009 04:24 PM
