bore on b16a2
bore on b16a2
i looked for a topic that would say what the bore is but i didnt find one, i got a 00 Si and want to know the bore and what aftermarket piston would fit without going overbore
thanks
thanks
Resident Gearhead
Re: (jason007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason007 »</TD></TR><TR><TD CLASS="quote">so the b16,b18c/c5 got 81.1mm bore? alright thanks</TD></TR></TABLE>
Yes <FONT COLOR="red">BUT</FONT> that is right out the factory door. Have it honed/measured <FONT COLOR="red">BEFORE</FONT> you buy new expensive pistons.
Man U FTW
Depending on mileage and condition of the cylinder walls, you may have no choice but to overbore to 81.5mm. Its not a bad thing to do on stock sleeves. The fresh bore will ensure a good seal for the new rings. IMO, its the best option.
Re: (Schister66)
And non-vtec LS's.
And non-vtec LS's.
alright thanks
what would be some good pistons to throw in there if i have to go overbore to.. 81.5mm? i've hear jp are good but i looked them up they go for 600 (set of 4 with rings)
Man U FTW
You may be able to get away with running stock bore, but personally i would rather overbore to 81.5mm and know that i'll have perfect cylinder walls.
What are your goals for the car?? You may not need to spend a ton on pistons unless you're looking to boost. There are stock replacement pistons available for a lot less money.
i want more power all motor but im not going to spend a lot of money or at least try not to, i have a b18b block sitting in my garage and i wanna rebuild it make it realiable but not spend a qhole lot of money
z6
07-18-2005 05:36 PM
EM1SiR
12-26-2003 09:50 AM
