Boost or not?
Old 07-03-2007, 03:57 PM
MDM
MDM's Avatar
Default Boost or not?
Well i have a D16Y8 with 166k miles.. i also have a junkyard turbo setup but im not sure itll hold since it has too many miles on it!!!
im also trying to work on a LSVTEC setup i have..
what do u guys recomend boosting 166k miles or save on LSVTEC???
TIA
Old 07-03-2007, 03:59 PM
SL!M's Avatar
Do a compression check and if the engine is in good shape and you take care of it I don't think it would be too bad. Just make sure its tuned correctly with your setup of choice and you don't boost too high. Good luck.
Old 07-03-2007, 04:03 PM
mikeycivic's Avatar
Default Re: (SL!M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote"> save on LSVTEC???
TIA</TD></TR></TABLE>
or do a b18 build
Old 07-03-2007, 04:05 PM
bmoua's Avatar
i'd since your working on a LS/V already might as well sell the turbo setup and get more parts to complete your LS/V.
Old 07-03-2007, 04:06 PM
97Ej6mike's Avatar
166k miles is up pretty high, id say youd probably benefit more from saving for your LS motor.
Old 07-03-2007, 04:10 PM
Agent_EM1's Avatar
Default Re: (97Ej6mike)
Don't boost... Save that money and put it towards the LS-Vtech... Or just kinda look around for a good GSR swap around the same price... I've seen some GSR swaps with under 100k go for around the same price as LS/V-tecs but then again... i'm a GSR guy so I guess my opinion is biased
Old 07-03-2007, 04:12 PM
mikeycivic's Avatar
Default Re: (Agent_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">Don't boost... Save that money and put it towards the LS-Vtech... Or just kinda look around for a good GSR swap around the same price... I've seen some GSR swaps with under 100k go for around the same price as LS/V-tecs but then again... i'm a GSR guy so I guess my opinion is biased </TD></TR></TABLE>
x2 and more reliable and less hassle
Old 07-03-2007, 06:20 PM
MDM
MDM's Avatar
Default Re: (mikeycivic)
yea i might do that sell turbo setup and ls and buy GSR... would that be a smarter choice??
Thanks all
Old 07-03-2007, 06:24 PM
lovey408's Avatar
Default Re: (MDM)
if this is gonna be ur daily driven car and ur not tryin to be the fastest u can den do lsvtec or gsr... but if u want speed i say sell the lsvtec and use it to build ur D series and den throw the turbo on it and get a good tune. but be prepared for a lot of downtime if u decide turbo.. but i gurantee u one thing. once u go turbo u wnt wanna go back lol i didnt
em1_racer's Avatar
Default Re: Boost or not? (MDM)
166k miles is pretty high...if the body of your car is still good then jut get a new engine if your body of your car is bot good anymore might as well get a new car. in my opinion anyways
Old 07-03-2007, 06:25 PM
MDM
MDM's Avatar
Default Re: Boost or not? (em1_racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_racer &raquo;</TD></TR><TR><TD CLASS="quote">166k miles is pretty high...if the body of your car is still good then jut get a new engine if your body of your car is bot good anymore might as well get a new car. in my opinion anyways</TD></TR></TABLE>
the cars good all it needs is pait so i might go GSR!!!
Old 07-03-2007, 06:27 PM
em1_racer's Avatar
yea if the car is still good then screw the d engine...go gsr
Old 07-03-2007, 06:28 PM
MDM
MDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_racer &raquo;</TD></TR><TR><TD CLASS="quote">yea if the car is still good then screw the d engine...go gsr</TD></TR></TABLE>
will do.. u think i could get one for about 1k???
Old 07-03-2007, 06:30 PM
em1_racer's Avatar
dont really think so...gsr's arent that cheap...unless its in a bad shape...most are well over about 2g's
Old 07-03-2007, 06:32 PM
MDM
MDM's Avatar
i have an ls i might sell and the turbo set up as well so i might get sumthing out of that!!
Old 07-03-2007, 06:33 PM
em1_racer's Avatar
just craigslist it and buy a new head for the ls and lsv it
Old 07-04-2007, 09:04 AM
MDM
MDM's Avatar
but an lsvtec is a pain to build.. specially when u have to drill for the oil from the block
Old 07-04-2007, 04:33 PM
96teggylsse's Avatar
you dont have to drill any hole.... i have 96 ls vtec and i just got the golden eagle conversion kit!!!
Old 07-04-2007, 05:54 PM
MDM
MDM's Avatar
Default Re: Boost or not? (96teggylsse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggylsse &raquo;</TD></TR><TR><TD CLASS="quote">you dont have to drill any hole.... i have 96 ls vtec and i just got the golden eagle conversion kit!!! </TD></TR></TABLE>
how does that work??
where did u get it??
how much??
lol
Old 07-05-2007, 07:35 AM
MDM
MDM's Avatar
FOUND IT!!!! now what type of pistons should i use....with feature boost plan..??
type r or b16???
Old 07-05-2007, 10:24 AM
MDM
MDM's Avatar
bumps..
what pistons??
Old 07-08-2007, 01:13 PM
im going to go with stock bore b16b (ctr) pistons when i rebuild they make about 12.3-1 or something like that with the gsr head.... what head are you using??? i guess it depends if you are going to go turbo or not later..... keep us posted
Old 07-09-2007, 07:39 AM
MDM
MDM's Avatar
yea thats the thing i heard its not recommended to use ctr's since i am going to be boosting in the feature and i dont wanna change pistons later on.. i might use a b16 head so i was also thinking b16 pistons and b16 tranny! so what do you all think..b16??
Old 07-09-2007, 08:06 AM
mikeycivic's Avatar
just buy a bare block and build it I may consider selling my setup, I have a bare b18c5 block with oil pump main caps and girdle, and brand new wiseco pistons and eagle rods for 81.5 mm bore and a polished ls crank
Old 07-09-2007, 09:49 AM
MDM
MDM's Avatar
Default Re: Boost or not? (mikeycivic)
i have an ls block too but thanks!
so what type of pistons??
Modified by MDM at 11:06 AM 7/9/2007
Quick Reply: Boost or not?
