bleeding clutch question - B16A2
I want to bleed my clutch but cant unscrew the bleeder screw. tried pretty hard to get it off, dont want to go too hard in case I snap it off. I sprayed it with lots of WD-40 but the thing wont budge. any advice on how to loosen the thing?
Seagull Management
Re: bleeding clutch question - B16A2
Heat it up and then spray a little cold water on it. If you really can't get it out you can try bleeding it at the line, or just replace the slave cylinder, that really don't cost that much.
Also, WD-40 doesn't work all that well as a penetrant, PB blaster or liquid wrench works far better.
I was told you cant adjust the clutch pedals on hondas :S
but I want to leave the pedal alone because I plan on replacing the clutch in about a years time
Seagull Management
Be really careful with this, as long as you follow that procedure you'll be fine. DO NOT just try moving the pushrod around till you get it where you want, set the freeplay and disengagment height, wherever the engagement point ends up is where it's supposed to be, just putting it where you want can cause clutch release issue, premature release beaing failure, and slipping.
Jdmkolb89
Honda Civic (2001 - 2005)
08-03-2012 10:10 PM
