bleeding the clutch
Re: bleeding the clutch (hakemjmba)
It's been a while since I've done this, but I'm pretty sure that you bleed them the same way that you would bleed your brakes. I the bleeder valve is underneath the car on the passenger side of the transmittion.
I'm not a 100% about the location, but I KNOW that it is somewhere close to there.
Good Luck!
Good Luck!
Re: bleeding the clutch (SpyderZEX)
the bleeder is on the slave cylinder..in front of the tranny..where the boot that covers the clucth release fork....u cant miss it..bleed it like u would the brakes..
you know what the bleeder valve looks like, cuz i looked under there and i saw nothing but bolts and one bolt the has a square in it, could it be that one?
is it possible to have a hole in the line or something because i tried to bleed my clutch with a bleeder tube like 3 times and it didnt work right just like halfway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hakemjmba »</TD></TR><TR><TD CLASS="quote">you know what the bleeder valve looks like, cuz i looked under there and i saw nothing but bolts and one bolt the has a square in it, could it be that one?</TD></TR></TABLE>
The square is either your fill or drain plug for the tranny.
The bleeder is the nipple on the end.
Re: bleeding the clutch (Trial User)
wow u guys thanks a lot, hopefully this fixes my clutch. my clutch is really soff and seems like there is no pressure to it, hopefully this fixes it! thanks!
riceburnah
06-02-2003 04:23 AM
