IAT sensor for P72. already searched...
Old Oct 18, 2003 | 02:45 AM
super laubo's Avatar
Default IAT sensor for P72. already searched...
i'm having massive problems trying to fix my CEL code 10. i've already rewired the sensor twice and swapped it to a slightly-used Accord IAT sensor. i thought that the ECU was bad so i swapped that also. the code still exists... i'm so damn frustrated and confused.. any ideas or help would be nice.. TIA..
btw, i have an OBD II P72 motor in a 96 EK...
~~edit~~~
also, i'm reading only 0.5V from pin D8.
Modified by super laubo at 12:20 PM 10/18/2003
Old Oct 18, 2003 | 09:27 AM
Default Re: IAT sensor for P72. already searched... (super laubo)
anyone???
Old Oct 18, 2003 | 09:35 AM
chrisCNL's Avatar
what harness are you using?
Old Oct 24, 2003 | 08:12 AM
exciv2000's Avatar
Check to see that both wires for the IAT sensor are connected from the sensor itself all the way to the ECU... Perhaps one is shorting out or is disconnected somewhere.
Old Nov 8, 2003 | 03:41 PM
jl21ah's Avatar
Does the code come on right when you turn the key? Or does it come on after a while? make sure to reset the ECU after changing the sensors.
anybody know where the ground for the IAT sensor goes on the ECU? Is it D7?
Old Nov 8, 2003 | 06:46 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super laubo &raquo;</TD></TR><TR><TD CLASS="quote">i'm having massive problems trying to fix my CEL code 10. i've already rewired the sensor twice and swapped it to a slightly-used Accord IAT sensor. i thought that the ECU was bad so i swapped that also. the code still exists... i'm so damn frustrated and confused.. any ideas or help would be nice.. TIA..
~~edit~~~
Modified by super laubo at 12:20 PM 10/18/2003</TD></TR></TABLE>
are you sure its a code 10? not a code 1?
roy ezechukwu
Feb 6, 2014 02:13 PM
ham
Apr 13, 2007 07:43 AM
andyt
Feb 20, 2007 06:08 PM
Dc_Ek
Aug 9, 2006 08:28 AM
kpkim87
Jul 28, 2006 08:15 PM
