Ball joint seperation
From what i read everybody has had trouble with these damn things. I searched this forum and all the other ones looking for something and nothing worked. I went and rented several tools at autozone and none of them worked. Then i saw this on youtube... http://www.youtube.com/watch?v=ISY8bGof3bQ And i thought i should share it because it works! I thought i was gonna have to haul my car to the garage.
Re: Ball joint seperation
that doesnt always work... the autozone ball joint separator tool works as well as banging the side of the arm that holds the ball joints.. what it does when you bang it with a hammer is that it loosens up all that rust and build up that may be keeping it stuck.. also a little use of Kroil will instantly loosen it up..
i tried all those and they didn't work. After i found this video it was off in 5 mins. I just thought i'd share it because i didn't see anybody else mention it and i looked at several different threads.
After several hours dicking around with a ball joint remover I gave up and searched. I found this video too. I used the video method during my swap. It worked like a charm. You just need the right sized wrench.
I agree wit the ball joint separator. the autozone/advanced/oriley ball joint separators tend to split the forks after so long and you need to press the forks back together.
i do not agree with the pulley puller. it will damage th metal threads on the ball joint, then you HAVE to replace the ball joints.
there are also pneumatic ball joint separators.
2000Accord5sp
01-30-2003 04:03 AM
