Ball joint seperation
Old 02-12-2010, 02:37 PM
New User
jjburton's Avatar
Default Ball joint seperation
From what i read everybody has had trouble with these damn things. I searched this forum and all the other ones looking for something and nothing worked. I went and rented several tools at autozone and none of them worked. Then i saw this on youtube... http://www.youtube.com/watch?v=ISY8bGof3bQ And i thought i should share it because it works! I thought i was gonna have to haul my car to the garage.
Old 02-12-2010, 02:39 PM
raidacaipo's Avatar
Default Re: Ball joint seperation
that doesnt always work... the autozone ball joint separator tool works as well as banging the side of the arm that holds the ball joints.. what it does when you bang it with a hammer is that it loosens up all that rust and build up that may be keeping it stuck.. also a little use of Kroil will instantly loosen it up..
Old 02-12-2010, 03:06 PM
95soul's Avatar
I used the latter method mentioned above. Randomly hitting the arm, and after 10 good hits, it popped right off.
Old 02-12-2010, 05:42 PM
HCivExoo's Avatar
spend the 10.95 on a great neck brand (auto zone ) ball joint seperator. they work i have never had one not work.
Old 02-12-2010, 05:45 PM
alphalanos's Avatar
works like a charm
Old 02-12-2010, 07:59 PM
New User
jjburton's Avatar
i tried all those and they didn't work. After i found this video it was off in 5 mins. I just thought i'd share it because i didn't see anybody else mention it and i looked at several different threads.
Old 02-12-2010, 08:03 PM
goldfinger93030's Avatar
you gotta be careful with the forks, they will mess up the threads on the joint ... thats the last thing you want
Old 02-12-2010, 10:18 PM
EJ8_Man's Avatar
After several hours dicking around with a ball joint remover I gave up and searched. I found this video too. I used the video method during my swap. It worked like a charm. You just need the right sized wrench.
Old 02-13-2010, 05:01 AM
xero_xero's Avatar
I agree wit the ball joint separator. the autozone/advanced/oriley ball joint separators tend to split the forks after so long and you need to press the forks back together.
i do not agree with the pulley puller. it will damage th metal threads on the ball joint, then you HAVE to replace the ball joints.
there are also pneumatic ball joint separators.
mr.tatertits
Suspension & Brakes
02-27-2016 05:42 AM
CARMA_626
02-22-2009 06:48 AM
keepitngga1
07-02-2007 05:48 PM
OTT
03-29-2004 02:09 PM
2000Accord5sp
01-30-2003 04:03 AM
Quick Reply: Ball joint seperation
