bad front rotors?
Old 10-08-2007, 10:14 PM
shotgun2224's Avatar
Default bad front rotors?
how do i know if i need new rotors cuz im changin my pads
Old 10-08-2007, 10:19 PM
been there done that
doood's Avatar
Default Re: bad front rotors? (shotgun2224)
does your brake pedal vibrate when you step on it?
Old 10-08-2007, 10:24 PM
nah it doesnt it just sounds like grinding bc my pads r too low that the safety pin is scraping
Old 10-09-2007, 12:25 AM
BlueIntegraBoy's Avatar
You are either supposed to shave your rotors or replace them every time you change pads. If the wear tab is making noise, there's a good chance it dug a groove in the rotor. Then you'll need to change them.
Old 10-09-2007, 09:58 AM
boots420's Avatar
your supposed to get the rotors turned every time you put new pads on. otherwise, if the rotors are scored it will put uneven wear on you new pads, thus making the life on your pads much shorter. its cheap to get em turned, $5 each around here.
Old 10-09-2007, 10:50 AM
excivicboy96's Avatar
If there is gouges in them or they are below the minimum thickness they should be turned or replaced.
Old 10-09-2007, 11:36 AM
themikewoo's Avatar
You replace the rotor is the lateral runout is too much.
Old 10-09-2007, 11:37 AM
fmrprojects's Avatar
Default Re: (themikewoo)
just buy new rotors, they are really cheap and save you some time. new rotors are like 15-25 bux. resurfacing them cost 10-15
vladd
08-02-2011 01:20 PM
wyee99
Honda Civic (2001 - 2005)
05-13-2009 03:11 PM
NuRon
03-10-2008 05:51 PM
cableboy
11-09-2004 12:26 PM
mr tl
09-20-2002 08:22 PM
Quick Reply: bad front rotors?
