Is this bad?
Is this bad?
If I run some aftermarket shocks such as KYB AGX without new springs? So just running all stock parts except for KYB shocks? What would the ride be like? Improved handling?
Re: Is this bad? (Hazem)
i wouldnt say itll approve the handling since you are still using the OEM springs which are soft. youll just be able to adjust the stiffness/softness of the struts.
Re: Is this bad? (yanta)
I need new shocks and it would be a long time before buying springs, if I even buy them. Will it be bad to go ahead and just get some quaility shocks while replacing them? Also, would it improve the handling of my car? Would you reccomend using the *****?
Thanks.
Thanks.
Unceasing Measure
These people have no idea what they're talking about. KYB AGX's work best with stock height or mildly lowered springs. Of course they'll tighten up your handling because A.) they're all around good shocks and B.) you can tune them to your driving preferences. Want to negate some understeer? Put the rears to full stiff and the fronts to full soft.
This is a good decision and the shocks will last for a good long while.
Re: Is this bad? (Archidictus)
Sweet, I figure 300 for the shocks and about 100 installation, is this a lot to drop into a 98 civic EX that I don't know the fate of? I mean, it's got 98k on a sohc and I have no money for a swap and no job, so would you keep it stock for a while? Shocks need to be changed within three months.
crxaddikt
09-06-2002 05:41 AM
