Back from vacation; car won't start
Have a 00' civic dx w/ 79k miles. Car has been great, no problems whatsoever until now. Car makes a whining noise when i turn the key and sounds like it wants to turn over and start.
Spark plugs were wet and would not spark; battery, fuses in the engine bay and under dash were checked and good, grounds checked, no check engine light. Tried jump starting the car with cables with no luck.
Spark plugs, wires, and air filter were changed 2 months ago.
What else could i check before towing my car to the dealership and having them check the timing belt?
Re: Back from vacation; car won't start
searched similar threads and videos and plan on checking my ignitor and coil tomorrow, any other suggestions?
check the coil and don't tow it to the stealership waste of like 500 dollars if not more..
if u are not getting spark its most likely ur distributor ur timing belt does not have to do anyting with this since the car stood
also to check if ur timing belt is ok just take off the valvecover and turn the motor over manually with a 19mm ratchet there is a bolt behind the driver side wheel has a little star shaped punch out turn it and if the timing belt turns ur fine doubt the car skipped timing or anyting just sitting there
test the coil first with a multimeter
Checked the ignition coil, had spark which made me believe it was the rotor and cap. Fires up now!
boobie1721
10
12-18-2007 03:56 AM
