car wont start any help???
New User
ok tonight my car just up and quit on me, i was driving about 25-30 when i looked at my cluster my battery and oil lights were both on, car just died and now wont start back up!!! WTF? i checked all my fuses good there what else can i check for? maybe clogged fuel filter? it turns over just no fire so i figure no spark or no gas????
any help?
any help?
Re: car wont start any help??? (B16aVtecCivic)
Also check to see that your timing belt didn't slip, if it skipped a few teeth, it won't start, no compression. Happened on my old B16, put the belt back to where it was supposed to be, and it started right up. If that's the case, redo your ignition timing on the distributor also.
anyone know if a 99-00 civic si distributor will work on my motor?
Don't forget one of the tracks you were on - No fuel. Sounds stupid, but you might be out of gas, or the pump might not be working, or the injectors might not be opening.
Shawn
Check relays i just had the same thing happen to me. They replaced my distibutor and ecu but no good it ended up just being a relay.
well there you go good job on the trouble shooting. you could try to goto a junkyard and get one if you dont want to buy a new one. i didn that with my old car.
keith
keith
Pworld925
12-31-2011 12:24 PM
89civicb16a1
11-19-2010 07:12 PM
sleepyitr
05-01-2008 04:22 PM
nighttrain33
03-23-2008 01:38 PM
