Back pressure??
Back pressure??
i have a 2000 si and i recently put a hytech big tube header a test pipe and a tsuedo n1 exhaust on my car...now the car idles funny..it only does this when the motor gets to running temp...i have a p0420 code stating that the catalyst is below threshold...i had that before i replace the exhaust but it was idling funny like it is...do i need to put a high flow cat on the car to create back pressure for it to stop doing this? or should i replace the downstream o2 sen. sinice i alreadt replaced the upstream one...i cleaned the iacv..even bought a new iacv and installed it same thing so i returned it...any suggestions?...the car idles from 1000 up to 2000 then back to 1000 constantly while siting at an idle then every once in a while it will go from like 1500 to 1800 very rapidly
Re: Back pressure??
The engine code is a separate issue from your idle problem. The P0420 code is to let you know when your cat is toast. Check the MAP sensor output voltage at idle.
Re: Back pressure??
The MAP sensor is a little vacuum gauge. If it's working correctly, it will show you how much vacuum is inside the IM. If the voltage is off then you start checking vacuum lines and closing off vacuum ports on the IM until you either find the leak or check them all. If no vacuum is leaking and the MAP sensor is off, replace the sensor.
Re: Back pressure??
just want to clear something up. there is nothing on your car or any car that needs backpressure. what they need is an exhaust system that is tuned to your engine so that you are getting good velocity down low(smaller diameter creates more velocity), AND is big enough to flow enough air so you arent choking it up high. for instance, a 3" system on a d16 or even a stock B16 or B18 is way overkill. it improves top end but kills low end torque, BUT a 3" system is still overkill on the top end too. so something like a 2.5" system should still give you just as much top end gains while keeping the velocity up down low to keep your torque up. NOW all of this applies to daily drivers. most forms of racing dont care one bit about low rpms.
Re: Back pressure??
i replaced the cat with a test pipe and an o2 sensor in the test pipe like i stated on the original post...but to newtron i didn tknow that...the honda guy at the shop said it needs back pressure...im just slow ruling things out to why my car idles like that at warm temps...im starting think its a vacume leak
Re: Back pressure??
but it only started doing this after i put the exhaust on thats why ia sked about the back pressure
Re: Back pressure??
Re: Back pressure??
yes scavenging is mostly found in headers where the exhaust charge of one cylinder passes the collector at the same time the next exhaust charge leaves the cylinder, this pulls the exhaust out of the cylinder and then the cycle keeps repeating.
Re: Back pressure??
You have no o2 sensor therefore your car cannot adjust it's fuel/air ratio correctly leaving you at a bad/rough idle. It's exactly how my car is, it idles fine when warmed up but wants to cut out when fresh started.
Re: Back pressure??
do people not read what is posted? i see this all the time in posts it drives me nuts....like i stated above i have 2 o2 sensors one on the header wich is brand new and one on the test pipe after the header which replaced the cat
Re: Back pressure??
Just because the sensor is new doesn't mean it works properly lol..
Re: Back pressure??
i didnt say that it would, and the chances of buying a new on and it not working are slim..i know it happens but its slim... u made the comment about not having any..if u would open ur eyes when u read then there wouldnt have been any confusion on your part...
Re: Back pressure??
Re: Back pressure??
Going-west
06-21-2009 07:57 PM
SuperCivic
06-15-2003 08:28 AM
