B20b Wont rev past 6k Please help asap
Old 09-18-2014, 02:04 PM
xKevis's Avatar
Default B20b Wont rev past 6k Please help asap
1993 civic DX
B20b low compression
from engine depot
Wont Rev Past 6k rpms
p28 chipped with b20 basemap from Xenocron
i tried other ecu's and same results please someone Help asap
P28 settings:
7200rpm revlimiter
2 step at 3500rpm
Old 09-18-2014, 02:06 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: B20b Wont rev past 6k Please help asap
Is the CEL on? Does it work?
Old 09-18-2014, 02:10 PM
xKevis's Avatar
no CEL the bulb is there too
Old 09-18-2014, 02:19 PM
NotARaCist's Avatar
Just because the bulb is there doesn't mean it works. When you turn your key to ON(II), does it come on for ~3-5 seconds, then turn back off?
Old 09-18-2014, 02:24 PM
xKevis's Avatar
it does work i had a check engine light before for 02 sensor and i fixed it
Old 09-18-2014, 02:26 PM
NotARaCist's Avatar
So when it hits 6k, does it feel like it's run out of power, or does it act like it's hitting a rev limiter? Have you checked your mechanical and ignition timing? Did you replace basic maintenance items when you installed the motor?
Old 09-18-2014, 02:37 PM
xKevis's Avatar
its hard to explain the car doesnt hit revlimiter but it forces me to shift
car runs fine
Old 09-18-2014, 02:38 PM
NotARaCist's Avatar
Then you need to check your timing.
xKevis's Avatar
but just wont pass 6k and it has a obd1 dizzy i changed everything all the internals to new to see if that would fix the problem
Old 09-18-2014, 02:41 PM
xKevis's Avatar
the timing belt is where is supposed to arrows pointing up and i did the timing light to and i did a valve adjustment
Old 09-18-2014, 02:49 PM
NotARaCist's Avatar
The internals of the distributor, or of the motor?
What color is your spark? Have you done a compression test?
Old 09-18-2014, 02:52 PM
xKevis's Avatar
idk ill check in a few wat color is the spark
Old 09-18-2014, 02:53 PM
xKevis's Avatar
and yeah the internals of the dizzy
Grupple
03-15-2016 02:53 PM
RWD_DC2
15
01-28-2013 10:12 PM
slow_srt
02-06-2007 08:08 PM
EFin' Kyle
14
11-01-2004 09:29 AM
Quick Reply: B20b Wont rev past 6k Please help asap
