b20 block heli coil help please!!!
well two of my head bolts holes are stripped out of my block on my b20/vtec swap and im going to do a heli coil but i bought the right size heli coil kit but the problem im having is the tap wont fit down into the whole all the way to the threads it goes down a little then the hole like seems to get smaller my friend suggest that we get a drill bit drill the hole out then use the tap any suggestions i need to get this car back together asap and this is causing alot of time lost on getting it back together.
Re: b20 block heli coil help please!!! (b20EG6vtec)
Your suppose to drill it out before you helicoil it! If you are unsure of what your doing I suggest taking it to a machine shop.
Re: b20 block heli coil help please!!! (TwoToes)
yes your suppose to drill it out with the tap that comes with the helicoils i know but the tap wont fit all the way down in the hole to reach where the stripped threads are and i dont want to make the entire hole threads with the tap.
sti99civicsi
16
05-07-2004 08:32 AM
