b20 eg
Re: b20 eg
Hope this helps!
92-95 EG with LS B18B Engine or B20.
Transmission: Use any Hydro B Series Tranny
Mounts: A combination of stock and Integra mounts can be used if a hydraulic B- series transmission is used. Don't forget the T-bracket for the rear mount.
ECU: Use the correct ECU or Chipped ECU
Electrical Differences: CX and VX need to convert to 4 wire o2 sensor. All models modify stock harness to fit.
Axles: 90-93 Integra axles, 94-up Integra axles, 94-97 Del Sol Vtec axles, or 99-00 Civic Si Axles. Note the intermediate shaft seal in the left side of transmission is different for 90-93 Integra Axles. Depending on Axle transmission Combo, It may have to be changed. Hasport Part#: EGBAXCMP
Shift Linkage: 94-up Integra linkage for Civics. 94-97 Del Sol Vtec linkage for Del Sol
Upper Radiator Hose: 94-Up Integra LS
Lower Radiator Hose: 94 Del Sol Vtec
Throttle Cable: 94 Integra LS Or CRV
Clutch Hydraulics: Stock
Air Conditioning: 94-95 Del Sol Vtec A/C bracket
Special instructions: Using OBD II ECU requires involved wiring modifications. Generally if the ECU you choose does not use the same plugs as the stock ECU, an Adapter harness will cut down on a lot of potential problems
krysted9354
06-03-2009 04:52 PM
B16ACivichtch
10-28-2006 11:44 AM
