B18C motor reassembly questions
Old 09-06-2011, 11:53 AM
darkstormcr's Avatar
Default B18C motor reassembly questions
Hi everyone,
I have a "piecemealed" B18C1 that I was looking to get put back together. The cams were worn, so I got replacement cams and also opened the bottom end for inspection. I am replacing the head gasket and many of the seals.
My question is -- what do I need to do to get the block/head back in sync, timing-wise? Is anything in the block relevant to the compression/relief stroke, or do I just set the block at TDC and then configure the head to match? If that is the case -- how do I know what position to start the cams at?
Thanks!
The Grumpiest
grumblemarc's Avatar
Default Re: B18C motor reassembly questions
Check the FAQs.
eg6madness
12-20-2012 05:36 PM
1.8
16
12-22-2004 03:25 PM
g2turbo
03-03-2003 07:23 AM
Quick Reply: B18C motor reassembly questions
