b18b1 reving problem..pls. help
Old 06-01-2008, 04:19 PM
swisscheese32's Avatar
Default b18b1 reving problem..pls. help
I just recently bought a 95 del sol with a b1b1 swap in it....when i start the car when the engine is cold the rpm's bob up and down but only when its cold....what could it be...
Old 06-01-2008, 04:26 PM
enigma's95's Avatar
Default Re: b18b1 reving problem..pls. help (swisscheese32)
so it idles funny when you first start it up? maybe the idle sensor? i had the same problem with my d16z6 a couple winters ago. it hasnt done it sense though. i went though last winter and it didnt do it so maybe it'll just go away.
Old 06-01-2008, 04:48 PM
Ice78transam's Avatar
Default Re: b18b1 reving problem..pls. help (enigma's95)
IACV, FICV, Def. a vacuum problem. check hoses around TB and back of intake mani for cracks/damage/missing.
Old 06-01-2008, 05:32 PM
elektronsi's Avatar
Default Re: b18b1 reving problem..pls. help (Ice78transam)
sounds like IACV, honda's tend to have that issue
Old 06-01-2008, 05:45 PM
Default Re: b18b1 reving problem..pls. help (elektronsi)
Can of intake cleaner can be your best friend.
Old 06-01-2008, 06:24 PM
aguon03's Avatar
check your IACV and also make sure you have no vacuum leaks. Also make sure you dont have air in your cooling system and double check your TPS and make sure it is getting the right voltage at close and open throttle. I had the same problem with my ride, (92 hatch w/ b16a2) my problem turned out to be the TPS and I also had some air in my cooling system. Works like a charm now. Good Luck
Old 06-09-2008, 07:29 PM
thanks for the help i'm pretty sure its the iacv
asianrepnsb
12
03-08-2008 12:26 PM
PinoyCivic
01-09-2006 11:34 AM
rice a roni
12
05-24-2005 12:31 PM
fast4w$
01-09-2004 10:04 AM
carcala
04-12-2002 01:22 PM
Quick Reply: b18b1 reving problem..pls. help
