B18B1 frankenstein swap info request
Ok...been working on this one for awhile trying to round up various parts. I've got a B18B1 out of a '94 Integra LS, also have harness and ECU from same car. I have a 5 sp tranny from a 99 GSR. These are going in my '93 si.
So I still need a distributor, axels and shift linkage.
My main question is, is there any difference in the axels from various integras? Meaning would I need to get axels from a GSR, or should I get them from a GSR?
As a side question, will the header and cold air intake from my d16z6 work with the b18? Doesn't look like any difference from what I can see. Although I'm probably going to ditch the cold air intake because my last engine was destroyed by a puddle of water. The new engine has the exhaust manifold on it, so it's not like it's a huge deal, but since I already have the header and the d16 is useless as anything but scrap now, i'd be nice to put it to use. Also, If i have to use the stock manifold will it bolt straight to the rest of the exhaust that I already have?
Modified by Banjo the Ninja at 11:48 AM 8/7/2007
Re: B18B1 frankenstein swap info request (Banjo the Ninja)
bump. tryin to get everything rounded up this week so i can do the swap this weekend. any help is greatly appreciated.
The d series manifold will not fit, and someone correct me if im wrong but the integra axles are all the same.
all axles for us tegs 94-01 are the same, if your ex has abs then you would need to get abs axles otherwise you can use either as long as they are for a manual trans
gl
gl
It's not vtec, and how would I tell if it has abs? It's a very low optioned si, manual doors manual windows, the only power options are the mirrors and sunroof.
1 Post
Re: (Banjo the Ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michael123 »</TD></TR><TR><TD CLASS="quote">the frankenistein its an lsvtec motor bro its gonna bit alot of work.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Banjo the Ninja »</TD></TR><TR><TD CLASS="quote">It's not vtec, and how would I tell if it has abs? It's a very low optioned si, manual doors manual windows, the only power options are the mirrors and sunroof.</TD></TR></TABLE>Frankenstein is the nickname for the LS/VTEC or B20VTEC combo. You can tell by the massive ABS pump located in the engine bay.
Ok, one more quick question and hopefully I'll be able to get this knocked out. Are the motor mounts the same on a 92-95 civic as the 94-01 integras? I know I have to get the rear motor mount from the integra. But when I pulled the old motor I noticed that my left motor mount is trashed. I can find integra motor mounts cheaper than honda mounts, but I need to know if they're the same before I buy them.
They look the same, and I would think they are since I have seen on here that you can just use the honda mounts when doing the swap, they must be the same.
u can only use 94 UP integra axles and LS and GSR are the same.
for the exhaust wise.u might need to have a muffler shop welded the down pipe and cat .
Re: B18B1 frankenstein swap info request (crazyguy)
Yea, I got the engine from a 94 LS, the tranny from a 99 GSR, the axels from a 96 LS, I'm going to buy a header then take the car to a local exhaust shop and have them build an exhaust system from the end of the down pipe back.
93civic_b18b1
08-21-2001 09:12 PM
