B18b swap transmision. problems shifting
Old 01-07-2011, 10:22 AM
j4s0n1337's Avatar
Default B18b swap transmision. problems shifting
I just put it in my 95 hatch about a week ago and it's already giving me problems. When I shift into gear it's kind of clunky, I have to push really hard for it to get into gear. Also, when I was driving today I was in second gear and it suddenly stopped accelerating, the engine was still revving, but it wasn't accelerating at all until I went into third. Does anyone have an idea of what this could be? Or is my tranny just a POS now?
Old 01-08-2011, 09:50 AM
j4s0n1337's Avatar
Default Re: B18b swap transmision problems
Could it be my shifter? has this happened to anyone else?
Old 01-08-2011, 04:59 PM
j4s0n1337's Avatar
No ideas? Anybody?!?
Old 01-08-2011, 05:02 PM
Seagull Management
94EG8's Avatar
What shift linkage are you using?
Old 01-08-2011, 06:52 PM
j4s0n1337's Avatar
b-series, I just replaced the clutch and changed the fluid before I swapped it in. I have no idea what's wrong with it, or if I need to get a new one?
Old 01-08-2011, 06:54 PM
Seagull Management
94EG8's Avatar
Which B-series? '90 - '93 teg almost works, its a tiny bit short and causes engagment issues but it will bolt up IIRC.
Old 01-09-2011, 01:18 AM
j4s0n1337's Avatar
It's from a 94 I believe. It's driving fine now but I'm super paranoid D=
Old 01-09-2011, 06:23 AM
devney's Avatar
Sounds a lot like a clutch issue to me honestly.
Old 01-09-2011, 07:01 AM
Former User's Avatar
Is the clutch pedal soft or spongy?
Old 01-09-2011, 07:50 AM
MonkeyMagic's Avatar
i'd have to lean toward this too.
OP, does it go into gear smoothly and easily when going from neutral to first at a red light?
does it grind shifting at higher rpm??
Old 01-10-2011, 12:43 PM
j4s0n1337's Avatar
It's not the clutch, the pedal's firm and I just bled the slave cylinder to double check. Sometimes it feels like it's slipping out of gear, and I can just push the shifter into place without my foot being on the clutch. I'm thinking it might be the shifter, but I'm not 100% on that.
Old 01-10-2011, 03:26 PM
devney's Avatar
Just because the clutch is new doesn't mean it isn't the clutch. When one of my springs popped out of my clutch disk, I had difficulty getting the transmission into gear at times. And the engine still revving with no accelleration is also a sign of a clutch going out.
Old 01-10-2011, 09:34 PM
j4s0n1337's Avatar
Guess I'm taking off the tranny for a better look, I'll keep you guys posted, if you think of anything else it might be let me know.
Old 01-11-2011, 06:29 PM
j4s0n1337's Avatar
I believe I've found the culprit... A broken off bolt for the pressure plate.
Idk how this slipped past me But I'm 90% sure this is the cause of my clutch problem. The springs seem pretty snug on there, everything else seems like it's in order but if you guys have any ideas let me know. I'm gonna fix the bolt and put everything back tomorrow after school, so I'll let you all know how that goes.
Old 01-13-2011, 11:44 AM
j4s0n1337's Avatar
Sooooooo, fixed the broken bolts, checked my clutch, everything seemed fine, but it's still happening. Only when I'm on the interstate though, it's weird. I don't think it's my clutch because when it stops accelerating it's still in gear, I have to feather the gas pedal. I think it might be my throttle cable or maybe my fuel rail/injectors? If anyone has an idea PLEASE let me know, I go up for inspection next month and idk if this is going to hold me up or not.
Old 01-13-2011, 03:06 PM
Cynical 1's Avatar
did you find the bolt head?
my thought is it is the clutch. the bolt head is jammed in the friction material, and is causing the clutch to slip...
Old 01-14-2011, 10:23 AM
j4s0n1337's Avatar
Default Re: B18b swap transmision. problems shifting
Yeah, I found the head. I don't think it's the clutch because when I lose acceleration Im still in gear I just have to take my foot of the gas and it'll accelerate again for maybe ten seconds
Old 01-14-2011, 03:48 PM
j4s0n1337's Avatar
Bumb for ideas
Old 01-15-2011, 08:52 AM
j4s0n1337's Avatar
morning bumb
baonest
12-19-2005 02:16 PM
num1rbffan
09-13-2005 11:08 AM
acuracy90
08-27-2003 03:58 PM
JustChou
04-18-2002 07:40 AM
Red2001GSR
02-18-2002 08:14 PM
Quick Reply: B18b swap transmision. problems shifting
