B18A1 into 95 civic - What intake should I use?
I want to put the B18a1 in my civic 1995. I have the complete wiring of engine b18a1 1992 automatic and the complet wiring of an engine b18a1 1995 man. the B18a1 1992 is an Automatic integra but a put a flywheel, clutch, etc.. On the Intake there was some differece with the intake of 1995 OBD1 and 1992 OBD1 and difference about EGR on automatic 1992. I juste want to know what Intake i Can fit on it, to have a normaly running of a B19a1 1992 Mnual ..? do i put the intake of a 1995 integra man.?! reste with the intake of 92 auto.?! put a intake of 92 man?! .. i don't know.. that my first Honda Swap ever.. At the moment my car as no engine and it was 1.6L VTEC SOHC automatic. I put a B serie inside , i have au omplet swap except my intake problem ... P.S. Sory for my English i'm in Québec city( Shawinigan) and i speak normally French, thanks for your answer .
Re: B18A1 into 95 civic - What intake should I use?
You can use the Civic engine harness or the 1995 integra engine harness. Swap the 1995 intake on if it's off a manual trans car. You could use the 1992, but you'd have to rewire the IACV I think, and need to use the 1995 injectors or the injectors from your old motor.
Your alternator, starter, throttle body, etc are all fine.
OK thanks because the 1992 automatic Integra 's intake have other vaccum and EGR valve system, and not the manual version! . If i put a 95 intragra's intake it will still run normaly ..?! I have just Injector of b18a1 1992.
Are you trying to put an automatic B series motor in your Automatic civic? If so youve got a host of other problems besides what intake to use.
BADGUYNY
01-14-2004 08:10 PM
