b16b vs b16a2
Re: b16b vs b16a2 (wm5holla)
I wrote something about your question on this thread. https://honda-tech.com/zerothread?id=496374
This may help you
This may help you
B16B block is 7mm taller then the B16A......
more agressive cams......diff intake manifold.....lighter intake valves....higher compression pistons with poly coat on the skirts.....thats just a few things I can come up with off the top of my head
do a search man. do you think you are the first to ponder this question? its been covered a MILLION times. stop being so damn lazy
b16b is a b18c5 destroked to 1.6l. The block shares the b18c5/b18c1 cast, and the head is still a pr3 casting with mild polish, more aggressive cams than a teg-r, stiffer valvetrain, bigger better manifold and throttlebody, high *** dome pistons, that are temp coated......basically, this motor is completely different than the b16a1/2/3
