b16b pistons in 16a?
have any of you installed civic R pistons in a b16a motor. I know they'll but was wondering about v to p problems that i may encounter using the stock rod length but going with Crower rods. I will also be running a civic R intake cam and integra R exhaust cam. Possible .010 on the head. What do guys think? Should work? one last question I was also told the the static compression would be raised to 11.1 from 10.2....is this correct? And have any of you used this combo with mighty B16a. thanks
New User
Re: b16b pistons in 16a? (CJ Fabrications)
yea, i have basically that setup and it works great! i have ctr pistons in b16a block with Portflow head milled .030 and run itr cams. with that much milling i had to change sparkplugs for a bit better clearance on the piston dome.
dont go as far as .030, but .010 ok.
psegs80
19
03-06-2006 08:30 PM
